Hello Guest it is June 11, 2026, 01:19:27 AM
Author Topic: Spindle pulley setup?  (Read 33281 times)
Offline dresda
  •  220 220
« on: February 15, 2011, 08:41:49 PM »
Bridgeport style mill with high/low with reverse back gear.
I set pulley#1 25-550rpm and ticked the reverse box,  set pulley #2 560-3800 If pulley#2 in selected in the config, spindle pulleys It says that way all the time as can be seen in settings screen.
When I change from high to low do I have to go into the config, spindle pulleys and change it to #1?
If I am in pulley #2 and in MDI I select s200m03 it doesn't change from #2 to #1 in settings screen, so if I change gear it still thinks it's #2 and goes backwards.
Ray.
Offline dresda
  •  220 220
Re: Spindle pulley setup?
« Reply #1 on: February 15, 2011, 09:43:02 PM »
I should say I'm using a VFD and DSPMC.
« Reply #2 on: February 15, 2011, 10:58:51 PM »
FYI - apparently the pulley reverse is broken in 3.43.22 (current lock down).
There was a bug in the spindle pulley reverse stuff that has been the subject of a thread on the Yahoo Mach list for the last couple of days. A new development version was just released today that is supposed to fix it (3.43.30).
www.CalypsoVentures.com
Offline dresda
  •  220 220
« Reply #3 on: February 16, 2011, 04:27:18 PM »
If I tick the reverse in the box it does reverse, I just want to know if I have to go into the config, spindle pulleys screen every time to change it from #1 to #2?
Ray.
« Reply #4 on: February 16, 2011, 04:55:06 PM »
You can change the currently selected pulley by changing the Spindle pulley DRO - in the stock 1024 screen set that DRO is on the diagnostics page. That avoids the need to go into the mach menus to change the selected pulley.
Ray.
Offline dresda
  •  220 220
« Reply #5 on: February 16, 2011, 09:41:39 PM »
Hi Dave, You mean the settings screen right? That's OK, so Is that what i have to do when I change gear? I thought by setting the speed ranges it would then know what range..
Ray.
« Reply #6 on: February 17, 2011, 02:17:37 AM »
You could alter your spindlespeed.m1s macro to look at your commanded speed and set the pulley DRO accordingly.
Offline dresda
  •  220 220
« Reply #7 on: February 17, 2011, 07:22:11 PM »
How does it normally work, I thought if you programmed your S command to the Pulley #setting it would it would change the # in the box in settings screen from 1 to 2, mine doesn't change.
Ray.
Offline dresda
  •  220 220
« Reply #8 on: February 17, 2011, 10:14:45 PM »
OK, I guess I have to go into the setting screen to select pulley #1 or 2 every time I want to change gears, I just thought by selecting the speed range assigned to each pulley  it would shift from 1 to 2 even though I still have to manually change gears.
ray.
« Reply #9 on: April 20, 2011, 03:34:14 PM »
dresda, I had exact same question about gear change until I found your post.  My conclusion is, better not forget to change gears when running a program.
I had another question, do you have a spindle index sensor on your mill?
I added a  spindle sensor to the top of my BP series 1 quick change tube and I think I'm realizing that I can't run it from there for the low gear because the index signal is actually read as 9 times faster than the actual spindle speed.
