Hello Guest it is June 11, 2026, 09:59:14 AM
Author Topic: Homing  (Read 13078 times)
Offline mhdale
  •  130 130
  • Knowledge is the Treasure.
    • Black Dragon Technologies
Homing
« on: January 23, 2006, 08:46:22 PM »
!! Warning !! ===>NEWBIE
My Home uses the X-- and Y-- and Z++ Limits for Home as well
It Seems that my system loses the Home NEG Option under the homing option or I just cant seem to get it to stick Either way it seems that sometimes When I hit HOME things move in the right direction and other times I hit HOME and it Moves X & Y in the positive direction which is NOT the right way.
Anyone have any hint as to what I might be doing wrong?
Mike
Re: Homing
« Reply #1 on: January 23, 2006, 08:54:00 PM »
Do the change to the home and limits. EXIT Mach3! This will save the xml and you should be good to go after that....
Try that and see if that fixes you up.
www.newfangledsolutions.com
www.machsupport.com
