Hello Guest it is June 09, 2026, 04:38:06 AM
Author Topic: Another newbie problem.  (Read 16534 times)
Re: Another newbie problem.
« Reply #10 on: February 14, 2011, 05:43:59 PM »
You just totally lost me. LOL
Milton
« Reply #11 on: February 14, 2011, 05:46:39 PM »
Ok if you can get internet access on the machines computer you can use that to attach your xml, if you cant then you could use a usb pen drive or something else like that to get the xml from the other computer and transfer it to your internet computer.
That will then allow you to attach it to your post.
« Reply #12 on: February 14, 2011, 06:34:58 PM »
I don’t even know what a xml is, just shows you how computer savvy I am.
Been trying to get this to work for two day’s, just about ready to stick Turbo cnc back on it. LOL
« Reply #13 on: February 14, 2011, 06:44:47 PM »
The xml is your config settings. If you open Mach and look lower right you will see the name of the profile you are using. Next go to your Mach3 folder and look for a file with the same name of your profile, it will have the .xml extension but you may not see that if you have not opted for windows to show known file extensions, so it will just be a file with the name of your profile that you will see.
