Hello all, I am trying to calibrate my dividing head (rotary axis) and am having the following problem. I am using the set steps utility in the settings screen and when I set the amount of degrees I want the divhead to turn a weird thing happens. If I set 360 degrees no movement occurs. If I set 359 degrees it moves 1 degree in the opposite direction. The position is correct but the stupid thing took a shortcut! If I set 330 degrees it goes 30 degrees the other way. Am I doing something completely dumb or should I operate the thing via a mirror
(lol) Any ideas?
Les
