Hello Guest it is June 09, 2026, 08:02:58 AM
Author Topic: Uneven cut on letters  (Read 20970 times)
« on: February 13, 2011, 07:27:25 PM »
I'm getting an uneven cut on letters in some spots. Everything is snug with no play on the machine, with all axis running smoothly. I noticed when it changes direction it has a bit of a jolt to it. I have Exact Stop enabled, with CV unchecked.
Acme 10 single start screws with Dumpster leadnuts
305 steppers 1/4 stepped
At present I'm running at 35 IPM on all axis
Mike Kearns
noveltysigncarver.com
Re: Uneven cut on letters
« Reply #1 on: February 13, 2011, 10:15:11 PM »
Run in CV mode. My thoughts are that the letters are made up of segmented lines, and your getting a bit of bouncing of your router when it starts and stops at each segment.
« Reply #2 on: February 13, 2011, 10:22:18 PM »
I just went and checked, and I was wrong. It is set in the CV mode, but distance and feed rate are off. The letters I am cutting were designed in a friends Vcarve Pro software.
« Last Edit: February 13, 2011, 10:24:36 PM by mlk1950 »
Mike Kearns
  •  9,356 9,356
« Reply #3 on: February 16, 2011, 04:39:48 AM »
If you post your GCode I can check it on my machine and this will at least rule out the possibility of a problem with the code.
« Reply #4 on: February 16, 2011, 07:20:14 AM »
How do I go about posting that?
Mike Kearns
« Reply #5 on: February 16, 2011, 09:12:09 AM »
Use the  additional options button on the reply page to browse your drive and attach the file.
  •  9,356 9,356
« Reply #6 on: February 16, 2011, 09:15:16 AM »
Same way as posting pictures.
The file must have a name that has not been used before on the forum and a file extension must be from the approved list shown.
« Reply #7 on: February 16, 2011, 12:31:11 PM »
Here ya go Tweakie. This was done in a profle tool path. I noticed when I did a dry run the Z was creeping up and then sometimes it would drop. I made some letters in my Cut2d in an inside profile tool path and the Z stayed steady as a rock. The only time it raised and lowered was going from one letter to another. Which I think is what it should be doing. Correct?
Thanks Mike
« Last Edit: February 16, 2011, 12:38:32 PM by mlk1950 »
Mike Kearns
« Reply #8 on: February 16, 2011, 01:16:32 PM »
Went and bought VCarve Pro 6. Did an inside profile on some large letters, an the Z was steady. Must have been bad code. All is good now, Thank you for the help.
Thanks Mike
Mike Kearns
« Reply #9 on: February 16, 2011, 01:22:55 PM »
Thanks Mike
Mike, if it is "single" line text I believe you should run the toolpath "on" the vectors. If the vectors are true type fonts you should use a "vcarve" toolpath. If you would like you can PM me and send me the Vcarve file and I'll take a look at it for you.
Mike
