Hello
Guest
it is
June 08, 2026, 11:32:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Denford Orac 8 station turret
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Down
Author
Topic: Denford Orac 8 station turret (Read 94127 times)
berty
74
on:
February 12, 2011, 05:12:26 PM »
Hi to all
I am trying to get a orac auto turret working
The bit I am struggling with is the three grey scale optic sensors
I have got a drawing from denford forum
Q . there are three wires returning from turret and different sequences will give different outputs combinations
Can mach 3 be configured to work out the 8 different tool locations
or will I need another board to convert the returning signals
cheers
Bert
cjmerlin
194
Re: Denford Orac 8 station turret
Reply #1 on:
February 12, 2011, 08:18:55 PM »
The 3 sensor wires output 12v on the original machine. You will need to convert this to 5v TTL input for most breakout boards.
If you are using a breakout board with opto-isolation the simplest way to convert the 12v is with a potential divider using 2 resistors and a zener diode on each of the sensor wires.
If your breakout board does not have opto-isolation then the purchase of an opto chip and resistors and veroboard would be a safer solution.
I have a macro for the Orac toolchanger but in the middle of rewriting it and will post once i've tested it.
See recent posting "Denford Starturn"
Hope this helps
John
Last Edit: February 12, 2011, 08:26:09 PM by cjmerlin
berty
74
Reply #2 on:
February 13, 2011, 06:05:01 AM »
Hi
many thanks for your reply
What is ttl
does the 5v supply need to come from the break out board for return reference
macro what are the and what do they do
cheers Bert
cjmerlin
194
Reply #3 on:
February 13, 2011, 10:31:53 AM »
TTL stands for Transistor Transistor Logic. It is a standardisation so all logic chips of that type can interface at the same level directly.
Attached is a very simple voltage divider that could be used with an opto-isolated breakout board.
A macro is a short "Basic" script that allows you to control Mach to do what you need.
berty
74
Reply #4 on:
February 13, 2011, 10:40:40 AM »
Many thanks for reply
Its all beyond me
What I will need is to know what wires go were ect as I am electronically challenged
bert
cjmerlin
194
Reply #5 on:
February 13, 2011, 10:57:10 AM »
Ok, This might be a problem as those resistor values will need playing with to get your 5v levels.
Lets try this another way. What breakout board do you have? Does it have 3 spare inputs.
berty
74
Reply #6 on:
February 13, 2011, 02:52:42 PM »
Hi the break out board is an old basic cnc4pc c1
The good news is that it is has 5v not 12v going in to it
bert
berty
74
Reply #7 on:
February 13, 2011, 03:02:13 PM »
Hi again I have just had a look at cnc4pc web site my one must be really old as it is very basic no charge pumps or relays fitted nothing like what they are showing on their web page just a hand full of processors
I have rechecked the input voltage to the board there is only the one and is clearly marked as 5v
Hope this helps
bert
cjmerlin
194
Reply #8 on:
February 13, 2011, 05:35:40 PM »
Hi, Your breakout board wont accept the signals from the toolchanger optos directly.
I dont know if there are any breakout boards that will accept a 12v signal input, perhaps an email to cnc4pc explaining your problem may help.
berty
74
Reply #9 on:
February 13, 2011, 05:54:13 PM »
Hi
I am bit confused as I was told the grey scale sensors were5v
I must admit that when I striped out the wiring from the orac for some reason I marked the wire as being 5 v I can only assume that I ever metered it or it was marked or connected to a 5v pin
Bert
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Up
« previous
next »
