Hello Guest it is June 11, 2026, 04:17:05 AM
Author Topic: Question for Breakin Wizard  (Read 5575 times)
Offline kolias
  •  1,165 1,165
« on: February 11, 2011, 02:42:28 PM »
Downloaded the file and I understand all except the following:
“Use Rapids: This will allow you to cycle back and forth between tool feed speed and rapids for your repetitions. If this is selected, rapids will be used for the initial positioning for the router and bit.”
What is Rapids and what is the meaning of the above?
“Alternate Sides Between Repetitions: Allows the Machine to do more of an X patter than a line back and forth at a diagonal”
What is the meaning of this?
Nicolas
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Question for Breakin Wizard
« Reply #1 on: February 12, 2011, 03:59:24 AM »
Rapids are where the machine attempts to do moves at the max velocity you've set in motor tuning. Rapids are G0 moves. This is as opposed to moves at your selected feedrate which are (for example) G1 moves. If you generate and examine the code from the wizard both with "Use Rapids" and without you'll see the difference.
if you don't select "Alternate sides" then the code generated describes a simple diagonal path. Try it to see. Use offline if you want to test it without machine movement.
if you DO select "Alternate sides" then the code generated describes a cross pattern. Try it to see.
Ian
Offline kolias
  •  1,165 1,165
« Reply #2 on: February 12, 2011, 07:17:04 AM »
Thank Ian for your time, now I got it
Nicolas
