Hello Guest it is June 13, 2026, 01:18:48 AM
Author Topic: Newbie. What am I doing wrong?  (Read 18923 times)
« on: February 10, 2011, 10:03:33 PM »
Hi all
Can someone give me a run down on creating a gcode please?
I am using cut2d which I have used to create a dxf file and I then use lazycam to open it and post gcode to mach3.
When I open it in mach3 it looks totally different to what I created.
Do I need to set up the tool details and material details in lazycam as well as specifying them already in cut2d?
Steve
Re: Newbie. What am I doing wrong?
« Reply #1 on: February 10, 2011, 10:12:53 PM »
Hey there Steve, welcome to the group !
Using Cut2D, there is no need to go through LazyCam. You would be best to just create the code right there with Vectric.
Cut 2D does it all, I think it will even post directly into Mach if it's running ... not sure tho, I do know SheetCam does.
There are some Vectric users her that are sure to help ya more,
Russ
« Reply #2 on: February 11, 2011, 01:04:11 AM »
Hi Overloaded
Thanks for the welcome.
I guess I need to rtfm again.
I never realized cut2d could output to other than dxf files.
i have now tried .gc and .tap as well however it is still opening oddly in mach3.
Should I be able to see the same shape as the file I created in mach3?
I made a sign with my daughters names on it and when I input it into mac3 it looks like a weird corkscrew shape.
« Reply #3 on: February 11, 2011, 01:11:20 AM »
Could be you need to change the IJ mode, its on General Config page.
« Reply #4 on: February 11, 2011, 01:29:05 AM »
It is set to inc at the moment.
« Reply #5 on: February 11, 2011, 02:03:47 AM »
Try it in Abs and see if the toolpath looks better.
« Reply #6 on: February 11, 2011, 06:12:39 AM »
STeve, have you selected the proper Post Processor in Cut2D ?
Use this one. (or mm)
« Reply #7 on: February 11, 2011, 05:13:04 PM »
I tried exporting as .txt for mach3. It is nearly right.
Changing from inc to abs in general config didn't work.
I can now see like a quarter of the item and it is miles away, I need to zoom in a lot to pick it out. I thought nothing was there to start with.
I also tried as an exercise to export it to .ngc and open it with linux's emc2 and it opens and displays perfectly.
I am positive the cut2d part is done correctly because I followed their tutorial to create it.
It must be a setting I haven't quite mastered in mach3.
« Reply #8 on: February 11, 2011, 05:38:11 PM »
Post the file if you dont mind.
Inch or MM ?
Where do you have the 0,0 origin placed ?
« Reply #9 on: February 11, 2011, 07:45:06 PM »
I use Cut2d and I always save mine as GCode Inch /Tap , and it always works fine.
Mike Kearns
noveltysigncarver.com
