Hello
Guest
it is
June 10, 2026, 05:14:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
mach3 close loop system
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach3 close loop system (Read 6975 times)
the_kop
28
on:
February 08, 2011, 10:40:57 PM »
mach3 close loop system can be made by contract from the liner scale and then make comparisons to the position.
Order to match or not. If not add value to the mach3 is calculated to order for another or not.
Thank you
Carnoustie, Scotland
Re: mach3 close loop system
Reply #1 on:
February 09, 2011, 02:17:11 AM »
Mach is open loop and the only closing of the loop that you will get is if you use servo motors, the loop will then be closed between motors and drives but it will not be closed back to Mach.
Print
Pages:
1
Go Up
« previous
next »
