Hello
Guest
it is
June 11, 2026, 04:36:43 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
NFS rectangular hole patern problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NFS rectangular hole patern problem (Read 16268 times)
fusion
37
on:
February 06, 2011, 02:55:39 PM »
Ron, I am having trouble with the rectangular hole pattern. I set the spacing to an array 2" x 2" spacing 6 holes in X and 2 in Y. See attached picture.
Here is the code I get:
(Code by Newfangled Wizard, 2/6/2011)
(Version 2.85)
(Program Posted for Aluminum )
G0 G49 G40.1 G17
G80 G50 G90 G98
G20 (Inch)
(***** Rectangular Hole Pattern *****)
M6 T7
M03 S1500
M9
G00G43 H7 Z0.25
G81 X1 Y-2.75 Z-1.25 R0.15 F20
X1.4 Y-2.75
X1.8 Y-2.75
X2.2 Y-2.75
X2.6 Y-2.75
X3 Y-2.75
X3 Y-0.75
X2.6 Y-0.75
X2.2 Y-0.75
X1.8 Y-0.75
X1.4 Y-0.75
X1 Y-0.75
G80
M5 M9
M30
The X dimensions are not right
Ron Ginger
925
Re: NFS rectangular hole patern problem
Reply #1 on:
February 06, 2011, 06:05:21 PM »
I dont see whats wrong. You asked for 6 holes, starting at X=1, and made the starting point the upper left corner. That causes the holes to spread out to X3.
Did you expect teh minus value for width to cause the part to be to the left? To do that set the start point as the upper right corner.
fusion
37
Reply #2 on:
February 06, 2011, 06:24:02 PM »
Nope,
I wanted the first X dimension to be a X=1, and that was OK. If the X spacing is 2, then the next holes should be at X=3,5,7,9,11. The code has them at X=1.4,1.8,2.2,2.6,and 3. The Y dimensions are correct.
Ron Ginger
925
Reply #3 on:
February 06, 2011, 06:29:25 PM »
The width value sets the total width of the array, it is NOT the spacing between holes. You should make width =11
fusion
37
Reply #4 on:
February 06, 2011, 06:38:47 PM »
Ah, Thanks!!! I misunderstood the graphic. Now it makes sense.
Print
Pages:
1
Go Up
« previous
next »
