Hello Guest it is June 12, 2026, 12:46:44 AM
Author Topic: Write wizard bounding box  (Read 31318 times)
Offline OCNC
  •  23 23
« on: February 02, 2011, 06:27:40 AM »
I'm wondering if there's a simple way to get the bounding box for any lettering produced via the Write wizard.
More specifically the easiest way to come up with the bounding dimensions.
Thanks.
Chris
Re: Write wizard bounding box
« Reply #1 on: February 02, 2011, 06:56:34 AM »
Hi Chris, welcome to the group !  :)
You can set the text start at 0,0 in the wizard, then post the code and look at the Program limits in the ToolPath screen.
Hope this helps you.
Russ
Offline OCNC
  •  23 23
« Reply #2 on: February 02, 2011, 07:07:18 AM »
Got it.  Thanks Russ
Russ
