May 27, 2012, 11:44:36 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Voltmeter
Pages: 1   Go Down
Print
Author Topic: Voltmeter  (Read 410 times)
kolias
Active Member
Offline Offline
View Profile
« on: February 01, 2011, 05:41:01 PM »
Sorry if this subject is not allowed here since it is not Mach related but there are a lot of knowledgeable people here and I thought someone may have an answer
I have this voltmeter (pic attached) and the probes at the end of each test wire are always coming off and it is very annoying and dangerous sometimes
I have try many ways to stick them together with no success (hot glue, duct tape, construction adhesive and various glues) They always come off because it seems that nothing sticks to the probes.
Anyone has a suggestion?
Nicolas
angel tech
Active Member
Offline Offline
View Profile
« Reply #1 on: February 01, 2011, 05:44:20 PM »
get a new set
wvancura
Active Member
Offline Offline
View Profile
« Reply #2 on: February 01, 2011, 07:15:02 PM »
The probe wires must be soldered to the probe tips to be of any value whatsoever.  Glue and tape are useless patches.
With that said, to solder them, you must be able to disassemble the tip from the plastic handle. Some tips are screwed into the plastic some are press-fit. The repaired wire must run through the plastic handle for best results.
It may be significantly easier to buy new probe leads.
Some meters are so inexpensive, that buying a whole new meter may be your best bet.
Bill
« Last Edit: February 01, 2011, 07:16:57 PM by wvancura » Logged
kolias
Active Member
Offline Offline
View Profile
« Reply #3 on: February 01, 2011, 07:52:03 PM »
Thank you Bill for your input
I will see if I can fix them the way you described. I have searched to buy new leads but I cant find locally any to fit.
I also know that they are inexpensive but I find mine easy to read and operate.
Nicolas
Bill
Nicolas
rickw
Active Member
Offline Offline
View Profile
« Reply #4 on: February 01, 2011, 09:36:29 PM »
I would try and solder them in place. All you really want is a good connection for the probe. Make sure you strip enough to get good contact before soldering.
Rick
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #5 on: February 02, 2011, 02:28:14 AM »
I vote for getting a new set of probes.
(As previously mentioned it may be cheaper to get a complete new meter which comes with probes).
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
