May 27, 2012, 11:43:51 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  PC Requirements
Pages: 1   Go Down
Print
Author Topic: PC Requirements  (Read 249 times)
p1lts
Holding
Offline Offline
View Profile
« on: February 01, 2011, 05:01:14 AM »
Hi all
Totally "green" newbie here. Inote that the PC requirements to run Mach 3 a re quite basic. I'll be loking to purchase an "old" box specifically to run my mill. jst one question. The website specifically requirs an off-board graphics card. Is this absolutley necessary?
Ian
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: February 01, 2011, 07:39:51 AM »
Hi Ian,
It is perhaps impossible to answer this one, some boards with on-board graphics may work OK whilst some will not. Mach itself needs a lot of the processors time and if the processors responds to an interrupt to service the graphics chip then the Mach timing may suffer and spoil the output pulse train.
Depending on the BIOS setup a PCI graphics card can often be used in preference to the on-board graphics chip which should then work OK (I have one such PC which works just fine but I have no idea of the board make and model).
Possibly the only way to be sure is to try it and see.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
