Hello Guest it is June 11, 2026, 10:39:23 PM
Author Topic: One-way direction in Z  (Read 18266 times)
Offline pgh3
  •  28 28
Re: One-way direction in Z
« Reply #10 on: January 29, 2011, 06:23:45 PM »
Port 1 is set to $H378 and Port 2 is left unchecked. Is this what you mean?
« Reply #11 on: January 29, 2011, 06:27:03 PM »
No I am meaning you have Port 2 entered for the Z axis Dir pin, see screenshot of your xml.
Offline pgh3
  •  28 28
« Reply #12 on: January 29, 2011, 06:45:00 PM »
Yes, that was a trial to see the effects - and this means you have the wrong version of xml - sorry about that.
I have since closed Mach3 and reloaded it - all axes still work correctly - and I've included the current xml.
« Reply #13 on: January 29, 2011, 06:47:25 PM »
If its working now then is it not likely that that was your problem previously? Will look at your xml but really not much I will see if its working.
Offline pgh3
  •  28 28
« Reply #14 on: January 29, 2011, 07:04:48 PM »
Yes, my thinking also - I'm puzzled because the only thing different between not working and working was a setting for Z of 8 & 9 and then back to 6 & 7, as per Angel Tech's suggestion.
And I'm afraid this is always going to be a possibility in this open-ended control system - that's why servos are so much better and expensive.
Again, thanks for your input and time. And yours, Angel Tech.
Offline pgh3
  •  28 28
« Reply #15 on: January 31, 2011, 10:01:12 PM »
I think I know what caused the problem before:  I had selected ECP as a print mode in BIOS - it should have been EPP!
My computer has the option to select both and I have - the Z axis has been both directions ever since.
I thought I need to share this information here so that anyone else with a similar problem may get a clue...
Thanks to all for your help.
« Reply #16 on: February 01, 2011, 02:03:22 AM »
Good to hear, thanks.
