May 27, 2012, 11:09:44 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Axis as Spindle?
Pages: 1   Go Down
Print
Author Topic: Axis as Spindle?  (Read 299 times)
spaceman
Active Member
Offline Offline
View Profile
« on: January 27, 2011, 07:13:10 PM »
I'm currently making a 3D printer and was wondering if I could use mach3 to connect the extruders.  I want it to have dual heads and can't seem to figure out how to connect the second head.  If it was a single head I'd just connect it as a spindle.  But with 2 heads, I'm not sure what to do.  Can an axis be 'turned on' without any Gcode? Can Mach3 be configured for dual spindles?
Any insight is appreciated.
Space...... out!
I let my mind wander once.... it never came back
ostie01
Active Member
Offline Offline
View Profile
« Reply #1 on: January 27, 2011, 11:43:57 PM »
Maybe you could use M3 for one spindle and M4 or M5 for the other
If this only for a 3D printer
You will probably have to manually update your Gcode for that.
Or any Mcode can do if you
This thread is for a dual spindle router
http://www.machsupport.com/forum/index.php/topic,16327.0.html
Search for others dual spindle threads
Jeff
Nitromuse
Active Member
Offline Offline
View Profile
« Reply #2 on: January 28, 2011, 08:18:20 AM »
The axis as spindle as toggle will get way too messy.  Just use M3/M5 for one head and M8/M9 for the other.  Of course you'll need an interface relay tied into your controller but they are out there at a reasonable price.
Hope this helps,
Pages: 1   Go Up
Print
Jump to:
