May 27, 2012, 11:02:01 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  dspMC/IP Motion Controller (Moderator: vitalsystem)
| | |-+  Pokeys and MPG
Pages: 1   Go Down
Print
Author Topic: Pokeys and MPG  (Read 767 times)
peter81
Active Member
Offline Offline
View Profile
« on: January 25, 2011, 12:21:24 PM »
Hello,
can somebody please help me with my home made pendant. I'm using pokeys and I have connected Mpg to input pins 1 and 2. All of the functions are working (LCD, start, stop, pause, axis selector, x1, x10, x100) except MPG. In mach3 settings page I can see MPG counts but axis dont move. What could be the problem?
peter81
Active Member
Offline Offline
View Profile
« Reply #1 on: January 26, 2011, 09:22:45 AM »
When I connect my pendant to a laptop at my home, MPG works ok and I can see the DRO counts, but when I try to run on my cnc computer I can't get any movement. I get message in status line: Already in joging mode! Can someone please tell me what should I do to make it work. Thanks.
Peter
peter81
Active Member
Offline Offline
View Profile
« Reply #2 on: February 02, 2011, 12:49:33 PM »
Has anyone succcessfuly connected mpg trough pokeys to use with dspmc? Is that possible or do I need to wire it to a hardware encoder input?
Peter
vitalsystem
Active Member
Offline Offline
View Profile
« Reply #3 on: February 04, 2011, 12:36:12 PM »
the mpg encoder should go to a hardware encoder, or a soft-encoder on the dspmc connectors.  see the manual for mpg.
regards,
Rufi
peter81
Active Member
Offline Offline
View Profile
« Reply #4 on: February 04, 2011, 12:52:16 PM »
Ok thanks Rufi. This means that I will have to replace usb cable from the pendant. Thanks.
Peter
Pages: 1   Go Up
Print
Jump to:
