Hello Guest it is June 12, 2026, 10:36:19 PM
Author Topic: Pokeys and MPG  (Read 29561 times)
Pokeys and MPG
« on: January 25, 2011, 11:21:24 AM »
Hello,
can somebody please help me with my home made pendant. I'm using pokeys and I have connected Mpg to input pins 1 and 2. All of the functions are working (LCD, start, stop, pause, axis selector, x1, x10, x100) except MPG. In mach3 settings page I can see MPG counts but axis dont move. What could be the problem?
Re: Pokeys and MPG
« Reply #1 on: January 26, 2011, 08:22:45 AM »
When I connect my pendant to a laptop at my home, MPG works ok and I can see the DRO counts, but when I try to run on my cnc computer I can't get any movement. I get message in status line: Already in joging mode! Can someone please tell me what should I do to make it work. Thanks.
Peter
Re: Pokeys and MPG
« Reply #2 on: February 02, 2011, 11:49:33 AM »
Has anyone succcessfuly connected mpg trough pokeys to use with dspmc? Is that possible or do I need to wire it to a hardware encoder input?
Peter
Re: Pokeys and MPG
« Reply #3 on: February 04, 2011, 11:36:12 AM »
the mpg encoder should go to a hardware encoder, or a soft-encoder on the dspmc connectors.  see the manual for mpg.
regards,
Rufi
Re: Pokeys and MPG
« Reply #4 on: February 04, 2011, 11:52:16 AM »
Ok thanks Rufi. This means that I will have to replace usb cable from the pendant. Thanks.
Peter
