Hello Guest it is June 12, 2026, 06:38:04 PM
Author Topic: Softlimit settings  (Read 23039 times)
Offline sn96
  •  60 60
Softlimit settings
« on: January 24, 2011, 06:59:42 PM »
Hello guys,
I have been playing with Mach3 trying to familiarize myself with the various menus and settings. There's a lot of settings! Anyway, In the motor home/soft limits dialog window it says "entries are in setup units". My units are set to inches but it appears that it is asking for mm values? It has to be mm because 100.00" would be over 8 feet long! that’s one huge milling table!
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Re: Softlimit settings
« Reply #1 on: January 24, 2011, 07:53:04 PM »
or an average sized router.
« Reply #2 on: January 24, 2011, 08:14:46 PM »
Dont let the big default numbers confuse you Mike. Units are units, just set them to the extents of your machine.
Imagine a 10 foot router ... setup in MM. That would be 3048 !
Offline sn96
  •  60 60
« Reply #3 on: January 24, 2011, 09:37:31 PM »
Ok I'm confused with the Z max settings. I keep getting softlimit errors that says "safe-z ignored, Z already higher than safe Z setting." When I try to start the program anyway, I get a pop-up that says "Soft limit warning.. continue? Yes /No" If I click yes, I get this error again "safe-z ignored, Z already higher than safe Z setting."
Here is a screen shot of my settings:
I have tried everything I tried swapping values clicking on reversed, home negative, larger values etc..
I tired the following:
MAX     MIN
5.00     0
0          5.00
5.00     -5.00
-5.00    0
Now I am completely confused. None of these settings seem to work. My Z has about a 5" travel.
Mike
windows 10
i7 laptop
« Reply #4 on: January 25, 2011, 01:14:09 AM »
Try with a  Z Max of 0 and Z Min of -5
« Reply #5 on: January 25, 2011, 04:40:17 AM »
don't worry about the "100" setting, that's just a default figure. Are you homing before you set the soft limits.
« Reply #6 on: January 25, 2011, 04:41:52 AM »
also your home speed is a bit high at 100%, i would normally not go above 30%
Offline sn96
  •  60 60
« Reply #7 on: January 25, 2011, 08:54:47 AM »
I think I tried this but I will try it again to see.
Mike
windows 10
i7 laptop
« Reply #8 on: January 25, 2011, 09:05:12 AM »
Make sure its that way round, ie the Max is the Zero and Min is a negative value equal to your travel.
Offline sn96
  •  60 60
« Reply #9 on: January 25, 2011, 10:31:36 AM »
Thanks for your help I really appreciate it.
I think I never tried those values to be honest. I did seem to have partial success when I set the Z limits to max 5.00 min -5.00, at least the soft limit errors went away, so it makes sense that max 0.00  min -5.00 would work. The problem I had with max 5.00 and min -5.00 was the zeroing. I wanted it to zero at 0 and not any other value.
I'm at work so I won't be able to try this until tonight. Bummer!
« Last Edit: January 25, 2011, 10:33:38 AM by sn96 »
Mike
windows 10
i7 laptop
