May 27, 2012, 02:58:07 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Help
Pages: « 1 2   Go Down
Print
Author Topic: Help  (Read 597 times)
Martynb
Active Member
Offline Offline
View Profile
« Reply #10 on: February 06, 2011, 01:54:55 PM »
Homing to start with
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #11 on: February 06, 2011, 01:58:42 PM »
You could try the automated setup for the inputs, I have never used it myself but looks like it should be easy enough to follow. Config menu then Ports and Pins then Inputs and you will see the button on the lower right of the page.
Pages: « 1 2   Go Up
Print
Jump to:
