Hello Guest it is June 12, 2026, 04:47:07 AM
Author Topic: Help  (Read 14469 times)
Help
« on: January 22, 2011, 12:34:19 PM »
Hope somebody can help
Ineed a syil x2 xml metric redy to go can some body help befor i pull my hair out
Re: Help
« Reply #1 on: January 22, 2011, 01:16:14 PM »
Do you have the imperial xml? If so then easy enough to make up a metric one, if you attach the imperial one I can quickly change it for you.
Re: Help
« Reply #2 on: January 22, 2011, 01:21:46 PM »
I downloaded the one from syil america but could not get it to work
Re: Help
« Reply #3 on: January 22, 2011, 01:24:28 PM »
Do you have a link to it?
What did not work about it?
Re: Help
« Reply #4 on: January 22, 2011, 01:32:50 PM »
I will change from my ipad to computer and down load a copy to you
Homing and limits the norm i supose any help
Re: Help
« Reply #5 on: January 22, 2011, 02:00:47 PM »
trying to send the file
Re: Help
« Reply #6 on: January 22, 2011, 02:28:38 PM »
Ok try this, I have not changed anything other than converting imperial to metric however some of  the pin numbers seem a bit strange, they could be correct but are certainly unusual.
Re: Help
« Reply #7 on: January 22, 2011, 02:36:27 PM »
thanks hood i will try it in the morning pin setings i will change tomorrow thanks i will be in touch
Re: Help
« Reply #8 on: February 06, 2011, 10:49:30 AM »
Hi hood tryed it to day changed the pins now how do you set up the rest of it
Re: Help
« Reply #9 on: February 06, 2011, 12:40:48 PM »
Whats working and whats not?
