Hello Guest it is June 08, 2026, 11:46:12 PM
Author Topic: Stepper moving in one dirrection only  (Read 17748 times)
Re: Stepper moving in one dirrection only
« Reply #10 on: January 22, 2011, 08:38:53 AM »
Hood it is that exact board.
« Reply #11 on: January 22, 2011, 08:50:51 AM »
Did you try swapping the inputs to see if the problem followed?
« Reply #12 on: January 22, 2011, 09:00:28 AM »
Just tried swapping inputs and the problem followed. So do you confirm that its the board?
« Reply #13 on: January 22, 2011, 09:01:11 AM »
If the ICs are in sockets try pressing them down in case  they are not seated properly, failing that hopefully the seller will sort you out.
« Reply #14 on: January 22, 2011, 09:14:26 AM »
Ok, I will try that. Thanks to both of you, you have been a big help.
