May 27, 2012, 02:48:15 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Pocket Wizard by Brian / Kiran
Pages: « 1 2   Go Down
Print
Author Topic: Pocket Wizard by Brian / Kiran  (Read 989 times)
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #10 on: January 22, 2011, 05:14:08 PM »
Yes, good idea Mr.P  Smiley
It will be an honor and a privilage to be associated with a helpful contribution along side the other fine work in there.
Russ
 Smiley
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Sage
Active Member
Offline Offline
View Profile
« Reply #11 on: January 22, 2011, 06:41:49 PM »
I assume you are referring to the standard wizards?
My stnadard wizard for rectangluar pocket looks nothing like the one you posted a picture of.
I'm running Mach 3.042.040
I'm wondering how to update the standard wizards.
(I just finished updating my licensed NFS wizards. They seem to be at 2.85 now.)
Sage
Sage
Active Member
Offline Offline
View Profile
« Reply #12 on: January 22, 2011, 07:11:17 PM »
Oops. My mistake. I see there are two rectangular pocket wizards - one beside "pocket cutting" and another stand alone rectangular pocket wizard.
Sort of confusing actually.
Sage
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #13 on: January 22, 2011, 07:13:36 PM »
Yup, thats why I made mention of them both a couple posts back. Smiley
Russ
Abe Lincoln
tjstamp
Active Member
Offline Offline
View Profile
« Reply #14 on: January 23, 2011, 03:50:45 PM »
i just want to say thankyou for the fix. i put in the info to do the job in the original config. and found the same prob. saved the settings and put in the fix and wa-la problem solved. great job people.
alenz
Active Member
Offline Offline
View Profile
« Reply #15 on: January 23, 2011, 04:07:14 PM »
Whew! Glad it worked. My batting avg can stand all the help it can get Cheesy
al
Pages: « 1 2   Go Up
Print
Jump to:
