May 27, 2012, 02:41:02 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Galil (Moderators: smurph, kcrouch)
| | |-+  Gantry homing problem
Pages: 1   Go Down
Print
Author Topic: Gantry homing problem  (Read 737 times)
MOTU
Active Member
Offline Offline
View Profile
« on: January 19, 2011, 02:24:53 PM »
Did an upgrade on a 4'x8' gantry style waterjet system using a Galil board (DMC 2143).
Using existing motors and analog servo drives (Advanced Motion Controls model 25A8).
Motion is spot on (jogs, runs parts, etc.) but with one problem ... when we try to home the machine, the right motor on the gantry moves faster (about 2X) than the left motor on the gantry.
Any ideas?
kcrouch
Active Member
Offline Offline
In way too deep!!!
View Profile
« Reply #1 on: January 19, 2011, 03:07:04 PM »
MOTU,
Please send a copy of your Galildebug.txt file.
Kenny
Having way too much fun! Something must surely be wrong.
smurph
Active Member
Offline Offline
View Profile
« Reply #2 on: January 20, 2011, 12:13:23 PM »
Make sure that the "Home slave with master" is not checked in the Mach General Config.
The Galil plugin puts the master/slave axis in gantry mode.  But if Mach sends movement commands to the slave axis, then the movement of the slave axis is doubled!
In the next release, I will handle this case in the code so that no matter how the General Config is setup, it will do the right thing.
But...  as Kenny said, a GalilDebug.txt file would be nice to verify this.
Steve
MOTU
Active Member
Offline Offline
View Profile
« Reply #3 on: January 20, 2011, 12:33:33 PM »
Just found out that someone here has already emailed you directly on this matter (I didn't know this and he has been out of the office).
I believe he has already sent the GalilDebug.txt file to you.
The "Home slave with master" is indeed NOT checked.
Steve
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #4 on: January 20, 2011, 04:46:38 PM »
Not sure how the Galil works, but if there's a slave, make sure the homing speed is the same as the master in Config > Homing/Limits.
Pages: 1   Go Up
Print
Jump to:
