Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 02:17:36 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Ref All Home not working
Pages:
1
Go Down
« previous
next »
Author
Topic: Ref All Home not working (Read 480 times)
Knotsaboutwood
Active Member
Offline
on:
January 13, 2011, 05:58:52 PM »
Hello,
I finally decided to setup my Z homing switch today and I'm not having much luck.
I've connected a wire to pin 13 and a wire to the 5V slot next to it on my breakout board. I've done an automatic setup of the pin in the software (Z home). I've enabled the Z home in Limits/Homing. I'm planning to have a simple plate and alligator clip to the bit.
When I click Ref All Home, I get nothing. The machine doesn't move. I've tried to ref the Z axis through Diagnostics also, but nothing there either. When I hook the wires together in Diagnostics the M3 Home lights up.
I did check to make sure that everything is working by adding in g code and a manual jog.
I have not hooked up the alligator clip to the spindle yet, does the pin wire need to be grounded for the software to recognize the switch?
Any ideas would be greatly appreciated,
KaW
Active Member
Offline
Carnoustie, Scotland
Re: Ref All Home not working
Reply #1 on:
January 13, 2011, 06:12:32 PM »
Should work fine, can you attach your xml just in case there is a config issue, however if the Home LED is lighting when you touch the wires it shouldnt be that.
Knotsaboutwood
Active Member
Offline
Reply #2 on:
January 13, 2011, 07:03:29 PM »
Hood.
I'm pretty new to doing anything with Mach 3 that doesn't involve me loading a file. Can you give me a heads up on where I can export the XML?
KaW
Knotsaboutwood
Active Member
Offline
Reply #3 on:
January 13, 2011, 08:33:51 PM »
Here's the XML
Mach3MillKaW.xml
(147.07 KB - downloaded 30 times.)
Active Member
Offline
Reply #4 on:
January 14, 2011, 03:07:52 AM »
Dont see a problem in the xml and when I press the RefAll button the Z axis moves.
Can you check that your RefAll buttons script is intact by going to Operator menu then Edit Button Scripts and then clicking on the Ref All button.
This is what the default has, 24 being the Z axis.
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
DoOEMButton(133)
DoOEMButton(134)
DoOEMButton(135)
Also have a look at the ticker window to see if there are any error messages there.
Knotsaboutwood
Active Member
Offline
Reply #5 on:
January 14, 2011, 06:43:42 AM »
Hood.
Thanks for looking at this. I'm out doing some quotes on work today, so I'll look at this later tonight.
Thanks again,
KaW
Knotsaboutwood
Active Member
Offline
Reply #6 on:
January 15, 2011, 01:46:12 PM »
Hood,
Everything looked fine there. I did notice that as I was sitting on the diagnostic screen, the M3 light would blink randomly 3 - 20 seconds. I'm wondering if it's not an issue with my parallel port.
Any other ideas?
Thanks again for your help.
Active Member
Offline
Reply #7 on:
January 15, 2011, 02:04:08 PM »
Sounds like you are getting noise, best bet is to shield the wries correctly but to mask the problem you could increase the Debounce Interval on the General Configs page. Try 2000 and lower if it works until you get the problem again then increase slightly.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
