Hello Guest it is June 10, 2026, 04:53:53 PM
Author Topic: Can a slaved axis have different steps/mm in motor tuning  (Read 22957 times)
Re: Can a slaved axis have different steps/mm in motor tuning
« Reply #10 on: March 12, 2011, 07:06:34 PM »
I've been fooling with this as well.
I got the jogging to work with the help of PoppaBear. It is excellent.
The HOMING works good too.
There is a modification to the PP over at SheetCam for the X to copy to B. However, it will not work with arcs, only point to point.
 Other problem is the MDI (no clue there yet)
« Reply #11 on: March 12, 2011, 07:18:22 PM »
The higher the resolution of the coupled axis, the more precisely they match while running code or jogging.
I tuned motor X to 40000 steps per, 100 ipm, 20 accel
                    B     30000         "            "            "
and they tracked within 0.0001 on the DRO's when stopped anywhere in a program run or while jogging at any speed.
Tuned to 2000 and 3000 steps per, or any other low resolution, they follow each other around 0.001 +/- due to the rounding I suppose.
« Reply #12 on: March 12, 2011, 07:18:57 PM »
I can modify a Vectric post if anyone needs it.
« Reply #13 on: July 30, 2011, 07:28:54 PM »
ger21 - I use Vectric VCarve Pro for my router.  Is that what you mean?
