Hello Guest it is June 12, 2026, 03:02:02 AM
Author Topic: Bug in Galil Found While Jogging with Keyboard Arrow Keys  (Read 9186 times)
« on: January 11, 2011, 02:54:26 PM »
When I jog the machine using the arrow keys on the keyboard, I get a runaway condition quite often. It will start jogging, and then just go crazy, zipping along down the table at breakneck speeds. I just looked at the code in the GalilDebug.txt file. I noticed that many of the commands don't have a comma between the value for the Z axis and that for the A axis. I think this is causing my problem. An excerpt from my GalilDebug.txt is attached.
My config is as follows:
4 axes: X,Y,Z,A - all servo reverse
X and A are slaved together (X is the master)
Has anyone else ever experienced this? Please advise.
Re: Bug in Galil Found While Jogging with Keyboard Arrow Keys
« Reply #1 on: January 11, 2011, 03:16:07 PM »
Also, I saw this in the debug file
State.nAixs = 4
Shouldn't that read State.nAxis = 4 ?
Offline smurph
  •  1,575 1,575
« Reply #2 on: January 11, 2011, 09:52:10 PM »
You have your axis mapping messed up.
This is from your GalilDebug.txt file:
ST ABCA
MO ABCA
Notice and there are two A axes in the command.  This means that you have the Mach A axis mapped to the Galil A(X) axis when it need to be mapped to you Galil D axis.  That will fix you up.
Steve
