Hello
Guest
it is
June 13, 2026, 06:35:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
parts/cycle counter
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: parts/cycle counter (Read 16426 times)
allanjs
49
parts/cycle counter
on:
November 13, 2006, 10:57:16 PM »
Hi all,
Is there a parts or cycle counter DRO ?
I sure can't find it if there is although I may
be looking for the wrong terminology.
Thanks in advance for the help.
Al
Brian Barker
3,860
Re: parts/cycle counter
Reply #1 on:
November 14, 2006, 06:22:53 PM »
Nope, not at this time...
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #2 on:
November 15, 2006, 01:59:29 AM »
Why not put a user dro on the screen, then write an M10.m1s macro, M10 is normally used for part counters.
(M10.m1s macro)
count=getuserdro(nnnn)
count=count+1
setuserdro(nnnn,count)
nnnn is a user dro number of your choice.
Graham.
allanjs
49
Reply #3 on:
November 15, 2006, 10:24:34 PM »
Thanks Graham,
I have tried this but it's not working.
Using screen4, I defined a DRO as OEM code 1000.
As I understand 1000 to 1254 are for user Dro's.
I edited the suggested macro code (nnnn) to (1000) and saved it as M10.m1s in the Mach3 macros folder.
I tried a few other things like calling it a OemDro but it made no difference.
Any other suggestions ? Or do you see what I may be doing wrong ?
Al
Scott
140
Reply #4 on:
November 15, 2006, 11:30:20 PM »
Al, I don't know if this will help you any, but there's another DRO that is set for 1000 already. The "Edge Finder Diameter" DRO on the Offsets page. I found some troubles with a touch off plate that had a thickness DRO set for 1000 and entering a value in one would change the other.
Just a thought.
Scott
allanjs
49
Reply #5 on:
November 16, 2006, 07:00:41 PM »
Thanks Scott,
That made me think a bit more and I came up with the answer.
There was already a macro called M10.m1s so I renamed it M12.m1s
as I don't use M12 for any thing. All I do is insert M12 at the end
of my programs just before M30.
Here is my final code that works.
Rem M12.m1s macro
count=getuserdro(1200)
count=count+1
setuserdro(1200,count)
Al
Graham Waterworth
2,785
Reply #6 on:
November 17, 2006, 03:04:26 AM »
Great, you got it working.
Graham.
Print
Pages:
1
Go Up
« previous
next »
