Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 01:46:00 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Easy question about 5V output
Pages:
1
Go Down
« previous
next »
Author
Topic: Easy question about 5V output (Read 373 times)
Grobich
Active Member
Offline
on:
January 07, 2011, 06:51:11 PM »
I'm hooking up my first CNC machine with Mach 3 and I was wondering if it was possible to get a constant 5V output from one of the parallel port pins. I would use this 5V as supply voltage for my limit switches (max supply current (8 ma). My limit switches are similar to those on page 37 of this manual :
http://www.dovermotion.com/downloads/knowledgecenter/DPS_MCH.pdf
G
Active Member
Offline
Carnoustie, Scotland
Re: Easy question about 5V output
Reply #1 on:
January 07, 2011, 06:59:04 PM »
I would either take a wire from one of the molex connections for a hard drive or if you dont want to go into the computer get a USB cable and chop one end off to bare the wires, red is 5v black 0v (or they should be) then you can just plug into any spare USB to get your power.
Tweakie.CNC
Active Member
Offline
Super Kitty.
Reply #2 on:
January 08, 2011, 06:46:51 AM »
Hi G,
It is really not a good idea to use the parallel port as you suggest. Either take the 5 Volts from the PC as Hood suggests or use a voltage regulator to get 5 Volts from your stepper driver supply.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
rrc1962
Active Member
Offline
Reply #3 on:
January 08, 2011, 12:08:16 PM »
Or just use small 5V power supply. I think I paid $14 for the last one.
DaOne
Active Member
Offline
Reply #4 on:
January 08, 2011, 01:01:12 PM »
USB is the best for this as it will most likely regulated to 500ma output. It will also have low ripple and the same ground return as the PP. This will help with noise as well as preventing problems if you pull too much current due to a short. The PP can be used if the input is pulled high. Most ports are this way. Use ground as the loop return and wire it so when a switch is pressed the contact is broken. This allows for multiple switches on the same input as well as an error if you have a broken wire. I would recommend using shielded wire to your switch as 5 volts requires a low noise floor. Another tip... Set your "Debounce" level to around 10 to start with under "General Config". This will help with noise by sampling out false signals as well as a bouncy switch issue.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
