Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 01:41:19 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Y Axis Issues
Pages:
1
Go Down
« previous
next »
Author
Topic: Y Axis Issues (Read 439 times)
RChadwick
Active Member
Offline
Y Axis Issues
on:
January 07, 2011, 01:16:25 AM »
I'm setting up my new machine (A Zen Toolworks Plastic-frame CNC), and I wanted to set up 0,0 in the upper left corner, and have what's displayed in the preview window cut out with the same orientation. However, I'm having a nightmare trying to set up the Y axis. I've tried every combination of 'Dir Low Active', and on the motor home/soft limits screen, 'Reversed', and 'Home Neg', and I haven't been able to configure it right. What I want to do is have it home right, move properly when I jog it (Yes, the Y will move opposite, but correct relative to the cutter), and have the DRO numbers move in the positive direction when moving away from 0,0. Is there a setting I'm missing? Am I going about all this wrong?
Active Member
Offline
Carnoustie, Scotland
Re: Y Axis Issues
Reply #1 on:
January 07, 2011, 03:16:04 AM »
DRO's will always count positive when the toolpath window shows you moving left to right for X and down to up for Y, it is convention.
Is there a reason you need to have it working opposite or is it just you want to home to that position? If its the latter then set a home off value equal to your X and Y axis distance and it should all work correctly. What that will do is when you home it will set the machine zero to the lower left and the machine coords DROs will show you are fully positive in X and Y when homed.
RChadwick
Active Member
Offline
Re: Y Axis Issues
Reply #2 on:
January 07, 2011, 10:09:20 AM »
Well, I have a fixture for cutting plexiglas sheets, and to hold it in the fixture, I push it into the upper left corner, with hold downs around the bottom and right edges.
ger21
Global Moderator
Offline
Re: Y Axis Issues
Reply #3 on:
January 07, 2011, 11:35:53 AM »
Mach3 uses a right hand coordinate system. What you're asking for would be a left hand coordinate system.
How are you creating your g-code? G-code for a RH system will give opposite results in a LH system.
You might be able to set the Y axis scale to -1, but the toolpath display won't show it correctly.
http://home.comcast.net/~cncwoodworker/2010.html
RChadwick
Active Member
Offline
Re: Y Axis Issues
Reply #4 on:
January 07, 2011, 04:26:47 PM »
Thanks for the responses. I think I didn't have my coffee before my last post. My CNC is set up like an engraver. If home is in the lower left, the tool will be in the way, and I'll have to always jog the cutter out of the way to access the work area. Since this is my first homemade engraver-type of CNC, I was going on my experience with an old New Hermes CNC engraver I used years ago, where 0,0 was upper left.
My G-Code is made by a script in D2NC. It was originally putting the output in the upper right quadrant, but I modified it to put it in the lower right quadrant.
I don't want to go down the wrong path, and cripple myself later with things like the toolpath not showing correctly. It's not too late for me to change the fixture, or my G-Code. What's the accepted way of handling this situation?
BR549
Active Member
Offline
Re: Y Axis Issues
Reply #5 on:
January 07, 2011, 04:46:18 PM »
Machine 0,0 can be anywhere you want it to be. Most cams allow you set the 0,0 where you need it. The machine does not care which quadrant you want to work in.
Just a thought(;-) TP
BR549
Active Member
Offline
Re: Y Axis Issues
Reply #6 on:
January 07, 2011, 05:21:08 PM »
You can always set up the uperLH as machine 0,0 and have the user 0,0 anywhere. If you want to send it to machine 0,0 then use G30, user home then G28.
stirling
Global Moderator
Offline
UK
Re: Y Axis Issues
Reply #7 on:
January 08, 2011, 06:07:01 AM »
Quote from: RChadwick on January 07, 2011, 04:26:47 PM
Just home top left and set home to be X0,Y100 (or whatever). i.e. whilst home is perhaps more commonly set to be X0,Y0 - it doesn't have to be, it can be whatever you like.
Ian
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
