Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 01:41:02 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
E-stop problem (new set-up)
Pages:
1
Go Down
« previous
next »
Author
Topic: E-stop problem (new set-up) (Read 373 times)
123srd
Active Member
Offline
on:
January 07, 2011, 12:48:07 AM »
Hi, I have a CNC4PC C10 parallel interface card which is plugged into my second parallel port (port 2). I have connected the E-stop into pin 10, switching +5 V and the pin 10 input set to pull down on the pcb. I can see the input working on the Mach 3 diagnostics screen, the lower 8th from right LED flashing on and off ,"input signals current state". The signal is set to active high and the signal is enabled in ports and pins. The E-stop works fine when testing without hardware inputs and set to active low.
Am I missing something here !!!
Active Member
Offline
Carnoustie, Scotland
Re: E-stop problem (new set-up)
Reply #1 on:
January 07, 2011, 03:31:43 AM »
Are you using a Normally Closed or Normally Open E-Stop switch?
Do you have the E-Stop entry in Ports and Pins Inputs set to Port2 Pin10 ?
123srd
Active Member
Offline
Reply #2 on:
January 07, 2011, 05:37:47 PM »
Hi Hood, I'm using a normally closed switch, so passing +5v back to the C10 board. I have set the E-stop entry in ports and pins to port 2 / pin 10. The C10 board for this input is set to pull down, so when the E-stop is activated Mach 3 will "see" 0V at the input which should activate the E-stop condition. This should operate as fail safe by using a NC switch if the cable is damaged.
As I mentioned, I can see the input being activated in the diagnostics page and I have tried different settings in Mach 3 and the C10 board. I'm assuming here that input 10 on the C10 pcb relates to pin 10 on the parallel port?
Any ideas you might have would be gratefully received!!
Regards, Sean
Active Member
Offline
Reply #3 on:
January 07, 2011, 05:41:10 PM »
I have no idea about the C10 I am afraid but most BOBs do have the pin numbers corresponding to the pin numbers of the port.
Can you attach your xml and I will see if I can find a problem in the config.
123srd
Active Member
Offline
Reply #4 on:
January 07, 2011, 06:42:44 PM »
Hi Hood, My last thought was correct, Mach 3 recognises this input via pin 5. The C10 user manual doesn't mention any input # / parallel port conversion. The C10 board has a female socket, so I'm using an old Belkin data cable with a male plug on both ends. I've just checked pin to pin with a multimeter and the Belkin cable is crossed and not pin to pin like a standard DB25 cable. I feel a bit silly now for not checking this sooner.... and having a background in automation!!
Many thanks for your offer of assistance, I'm sure to post help requests again when I get into software limits and fixtures.
All the best, Sean
Active Member
Offline
Reply #5 on:
January 07, 2011, 06:47:36 PM »
Good news, yes these crossover cables can be a PITA
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
