Hello Guest it is June 12, 2026, 06:55:29 PM
Author Topic: Mach3 input dialog box for Z-axis offset  (Read 18227 times)
« on: January 04, 2011, 03:07:19 PM »
On my plasma table, I set my Z-axis offset in HOMING/LIMITS.  Because the material I'm cutting flexes differently depending on the location of the table, I'm constantly having to reset my Z-axis offset by a couple hundredths...
Is there a dialog box in machscreen that I can use to type in my z-offset and send the amount to the HOMING/LIMITS settings?  Tool and fixture offsets seem to do no good...?
Thanks!
Re: Mach3 input dialog box for Z-axis offset
« Reply #1 on: January 04, 2011, 03:41:41 PM »
The Z offset in homing/limits only affects your zero position in relation to your home switches. It makes no sense at all that you're using it as a Z axis offset while cutting, as it doesn't do anything except when homing.
The Z fixture offset should change your offset immediately. After entering a number in it, be sure to hit "enter" for the number to take. This should immediately be reflected in the Z DRO.
« Reply #2 on: January 04, 2011, 05:54:55 PM »
I tried that, but every time I REF-Z, it resets my fixture Z offset back to 0.00???
« Reply #3 on: January 04, 2011, 06:19:47 PM »
It's supposed to. That's what referencing is.
But, if you don't want it to, uncheck " Auto Zero" in Homing/Limits.
« Reply #4 on: January 05, 2011, 09:40:10 AM »
AHHH... Let me try that!
I also have a question emailed to Hypertherm support about using their Ohmic sensor cap as a Z-axis home switch.  This may solve all my problems with flexing material...
« Reply #5 on: January 30, 2011, 04:52:02 PM »
Can you tell me how you are wiring the ohmic sensor cap as a home switch? How is it wired to complete the circuit?
« Reply #6 on: November 17, 2012, 02:47:40 PM »
hi there, my x/y/z moving distance are different from the screen shown, what's the problem?
