May 27, 2012, 01:27:23 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Making a list of things that need fixed in Turn
Pages: « 1 2 3   Go Down
Print
Author Topic: Making a list of things that need fixed in Turn  (Read 1204 times)
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #20 on: January 05, 2011, 09:36:26 AM »
The way it works now (OK, should work...) you will utilize your whole available speed range in the above example. Do you want to restrict it?? Don't follow you.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #21 on: January 05, 2011, 09:38:46 AM »
You need a better spindle motor Wink
I will have to read that a few times more  later on when I get some time but from first read is that not exactly what it should do if you have a min and max spindle?
M250cnc
Active Member
Offline Offline
View Profile
« Reply #22 on: January 05, 2011, 09:51:22 AM »
I wondered how long before you started bragging about your spindle motor.  Grin
But the point is i do not know how it should react.  Sad
Phil
Active Member
Offline Offline
View Profile
« Reply #23 on: January 05, 2011, 10:02:53 AM »
I never bragged, just simply pointed out that yours is a bit of a sub standard spare part  Grin
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #24 on: January 05, 2011, 10:48:51 AM »
AH HA!! found my issue Hood, and Rich........
  I was Using CSS G code generated by my CAM, I swithced to the F/rev and POOF problem when away......
So, I must revise my threading request:
1). Fix CSS?
Rich:  I sent you a PM take a peek.
scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Active Member
Offline Offline
View Profile
« Reply #25 on: January 05, 2011, 10:52:33 AM »
Great news Scott Smiley
Global Moderator
Offline Offline
View Profile
« Reply #26 on: January 05, 2011, 05:34:05 PM »
I'm  happy you found the culprit Scott.   Smiley Another red note placed in the writeup for future update. Wink
You just can't image how much checking went into getting the thread lead right.
DAlgie
Active Member
Offline Offline
View Profile WWW
« Reply #27 on: January 06, 2011, 11:32:47 PM »
A nice improvement for Turn would be on the Tool page. I use slow feed to move close to the stock or an electronic edgefinder, then switch with jog mode to a 0.001" resolution incremental jog and bump it to touch that way. There is no button on the Tool page so you can switch between continuous jog and incremental jog, so I have to keep switching back and forth between the two pages to set multiple tools. Just a thought.
Dan13
Active Member
Offline Offline
View Profile WWW
« Reply #28 on: January 07, 2011, 01:40:45 AM »
Holding down the Ctrl key while using the jog buttons will switch you to incremental mode.
Pages: « 1 2 3   Go Up
Print
Jump to:
