Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 01:09:13 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
HELP! no lpt output. (advanced)
Pages:
1
Go Down
« previous
next »
Author
Topic: HELP! no lpt output. (advanced) (Read 452 times)
zygoat
Active Member
Offline
on:
December 31, 2010, 08:08:27 PM »
im new here, and to mach. been doing my research for a while tho. really good with computers and electronics.
here is the problem.
i get no output from the parallel port (lpt). when i try to jog the axis (x,y,z,a). i have verified this with a multi meter directly at the port on the motherboard.
HERE IS WHAT I HAVE DONE.
i am running the latest version of mach. Mach3 R3.042.040
ran the mach3 driver test. (it works perfectly)
i uninstall ed and re installed the mach driver (per the manual, meaning i deleted all traces of the driver from my system)
i uninstall ed and re installed mach (with a new download)
i uninstall ed and re installed the parallel port driver (windows)
i tried installing a pci parallel port add on card.
i verified and tried different ports and pins for everything.
the parallel port addresses are correct.
i tried changing the different bios settings for the parallel port
im at a loss right now. there is no output coming from the axis ports. i DO get a charge pump signal. it seems to work fine. but nothing else does.
if you have read the above and can think of anything else for me to try please let me know.
Active Member
Offline
Carnoustie, Scotland
Re: HELP! no lpt output. (advanced)
Reply #1 on:
December 31, 2010, 08:12:10 PM »
Attach your xml and someone will have a look and see if there is a config error.
zygoat
Active Member
Offline
Reply #2 on:
December 31, 2010, 08:23:49 PM »
xml
zygoatsMach3Mill.xml
(146.51 KB - downloaded 31 times.)
Active Member
Offline
Reply #3 on:
January 01, 2011, 03:42:21 AM »
Ok first thing I see id your X axis is set to Port 3 for both Step and Dir, that is not correct.
I also see you have the E-Stop set to port 0 which I will presume means you dont have an E-Stop switch connected, if thats the case then you will probably need to set it Active Low so that when you press the Reset button it will stop flashing.
zygoat
Active Member
Offline
Reply #4 on:
January 01, 2011, 04:20:10 PM »
I got it working!
the problem was with the cable. i bought a "lap link" cable. which swaps pins from one end to the other. = not good.
x axis on port 3 was due to my testing the secondary lpt port card that i added on.
and yes no e stop yet. i will change it when i get one hooked up.
thanks for your help.
Active Member
Offline
Reply #5 on:
January 01, 2011, 04:24:19 PM »
Just for your reference, if using the parallel port for outputs you will never have an output to port 3 as even if you have two ports they are still either port 1 or port 2.
zygoat
Active Member
Offline
Reply #6 on:
January 01, 2011, 05:03:50 PM »
I know, I was just "trying everything" as the port on the computer was lpt 3. I tried port 2 previously.
Again. Thanks for the help
Active Member
Offline
Reply #7 on:
January 01, 2011, 05:05:18 PM »
No probs, was just in case you had not realised and it got you stumped in the future
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
