May 27, 2012, 01:01:26 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Jogging off the stops
Pages: 1   Go Down
Print
Author Topic: Jogging off the stops  (Read 262 times)
jimthefish
Active Member
Offline Offline
View Profile
« on: December 30, 2010, 03:20:02 AM »
Hi, my Mach3 crashed last week, I reprogrammed in all the config and got it all back to normal. However when I hit the stops I can't get the axis to jog off the stop. I'm sure there was a tick box to allow you to jog off the stop but cant remember how I did it. Can anyone JOG my memory
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: December 30, 2010, 03:34:05 AM »
Auto Limit Override on I think the settings page.
jimthefish
Active Member
Offline Offline
View Profile
« Reply #2 on: December 30, 2010, 03:39:38 AM »
Hi Hood, I knew you would know mate. Thanks, How are you, Jim
Active Member
Offline Offline
View Profile
« Reply #3 on: December 30, 2010, 03:41:58 AM »
Fine Jim Smiley
BTW you may want to look at setting soft limits also as it will prevent you from hitting the limits in the majority of cases.
jimthefish
Active Member
Offline Offline
View Profile
« Reply #4 on: December 30, 2010, 03:49:55 AM »
OK will do. Just for reference the machine has run perfect since you helped out. I make Model Steam trains down in a small workshop down the garden. It got so cold over the past couple of weeks I think it froze the machine, had to put some heat into the machine castings via a blow heater. When I came to switching on the computer the Mach3 setting had dissapeared, frozen out?. Still all OK now, back to my chu chues. Jim
Pages: 1   Go Up
Print
Jump to:
