Hello Guest it is June 09, 2026, 09:52:24 AM
Author Topic: Text Wizard  (Read 7725 times)
Text Wizard
« on: December 26, 2010, 12:21:30 AM »
I am trying to cut some text using the mach 3 text wizard and having some problems.
The first problem is the text will cut much larger than what it is set to cut.
The second problem the text when generated will appear so far off the table I am not ale to get it in position for a cut
Any help would be great
Re: Text Wizard
« Reply #1 on: December 26, 2010, 03:47:21 AM »
On the left hand side you tell it where you want it to start in X and Y  and as for the size, it could be you are using metric setup on your machine but have chosen inch in the wizard.
