Hello Guest it is June 09, 2026, 03:25:15 PM
Author Topic: Axis won't move continuous  (Read 16663 times)
« Reply #10 on: December 27, 2010, 09:00:57 PM »
Yes.
Re: Axis won't move continuous
« Reply #11 on: December 28, 2010, 06:12:39 AM »
Can you attach your xml please and I will see if I can find a problem there.
« Reply #12 on: December 28, 2010, 08:19:00 AM »
I figured it out.
It seems to work properly when I turn on "Charge Pump on in estop"
I thought that disabled the gecko when you activated the reset on the screen. Now when you activate the reset on the screen the drives/motors are still powered up. Thinking about it it makes since though, now the motors are still holding their position while mach is not giving them a command.
Why would that effect the external e-stop?
« Reply #13 on: December 28, 2010, 08:42:04 AM »
I dont know but may be something to do with the way the G540 works.
