Hello Guest it is June 09, 2026, 07:02:08 AM
Author Topic: somethings keeps getting reversed  (Read 21266 times)
Re: somethings keeps getting reversed
« Reply #10 on: December 21, 2010, 04:42:09 PM »
1.43 is the min you can set but I wouldnt go too high, try 10 and see.
« Reply #11 on: December 21, 2010, 04:44:29 PM »
Thanks Hood!!! :)
Happy Holidays and Merry Christmas!!!
« Reply #12 on: December 21, 2010, 06:00:45 PM »
I set it to 5 and the rset thing happened again. I set it to 3 and now trying again.  :(
« Reply #13 on: December 21, 2010, 07:13:29 PM »
Pray it keeps working - this is the furthest in this particular job I have ever gotten.
It is a Celtic design..... Not done cutting yet. But very hopeful...
« Reply #14 on: December 22, 2010, 01:54:43 AM »
Hope you have good luck.
How old is your SS?
« Reply #15 on: December 22, 2010, 08:04:14 AM »
I just bought it less than a month ago. It ended up resetting the red button again. aauugghh
« Reply #16 on: December 22, 2010, 09:40:59 AM »
Sounds like you are getting bad noise on the E-Stop or limits, have you got them shielded?
Another thing to look at is I see you have a laptop and it wont have an earth to the mains, it could be worthwhile grounding the SS itself via jumper and the mounting screw. Have a search for Dan13 as I think he had to to that for his laptop.
« Reply #17 on: December 22, 2010, 04:58:06 PM »
Found his posts. thanks!
I just grounded the board and will post if it works or not.
« Reply #18 on: December 22, 2010, 05:52:05 PM »
Not sure if you can see very well in this picture or not. I took the ground port for the external power supply on smooth stepper and grounded it on a screw on the 2x3 CNC machine.
Let's see if this works. I am running a job now that it has always happened on. See what happens this time.
« Reply #19 on: December 22, 2010, 05:56:42 PM »
It did it. Let's pray it keeps going like this. WOW!!!! It's amazing what a little piece of wire can do.
THANKS!!!! If it happens again I will post here letting you know. Mean time THANKS!!!!!
