Hello Guest it is June 11, 2026, 08:04:52 AM
Author Topic: Why does my A axis motor not work?  (Read 8023 times)
Offline gjp
  •  9 9
« on: December 21, 2010, 09:43:39 AM »
Hello,
I am having a problem which could be either hardware or software.  My CNC is a 4 motor set up (X&A, Y, Z) running on a Rockcliff board.
Currently the X, Y, and Z motors work, while the A axis motor does not.  I even hooked the motor up directly to the Rockcliff board to test it.  However, when I check the trim pot voltage on each of the 4 axes, each one reads 2VDC as they should.
The Keling motor does work, in fact, we went ahead and ordered a new one (only $40), before discovering that the motor wasn't the problem.  (It is probably a good idea to have a spare on hand, so I don't mind the expense.)
I am not an expert on how the Rockcliff boards work, but ours appears to be normal, yet the A motor does not function.  I am also posting this message to the Rockcliff forum to get help there.
Is there something I did in Mach3 to cause the A axis to not work properly?  Is there something I can test to find out?
Re: Why does my A axis motor not work?
« Reply #1 on: December 21, 2010, 03:43:34 PM »
Try swapping the pin assignement in Mach from X to A and vice versa and see if the problem stays wit the same drive/motor or swaps.
Offline gjp
  •  9 9
« Reply #2 on: December 22, 2010, 09:10:51 AM »
I swapped the pin assignment and there was no change to the system.
My healthy hunch is that is a problem with the driver board.  I am hoping someone from Rockcliff will assist me in diagnosing what is probably a problem with the board.
« Reply #3 on: December 22, 2010, 09:21:32 AM »
Next thing to try is swap the drives if it is possible.
