Hello Guest it is June 10, 2026, 02:13:38 PM
Author Topic: Y Axis racking when sent to "Home"  (Read 8819 times)
« on: December 20, 2010, 07:10:28 PM »
I have 2 steppers on the y axis gantry which is R&P one on each side, they are the same brand, bought at the same time. Well the problem is when I "Home" the Y axis, one motor runs faster than the other. The odd part is when I jog or say "Go to zero" then they are fine. Any Suggestions? Thanks   Richard
Re: Y Axis racking when sent to "Home"
« Reply #1 on: December 20, 2010, 08:44:58 PM »
In config check the Home speed % for each motor sounds like one is differrent.
« Reply #2 on: December 20, 2010, 10:27:47 PM »
Same thing happened to me the other day. Terry's answer is correct.
« Reply #3 on: December 23, 2010, 05:45:49 PM »
Thank you very much!!! That was it.
