Hello Guest it is June 11, 2026, 08:53:53 PM
Author Topic: can closed loop spindle control be used to trigger estop when rpms wrong?  (Read 8396 times)
Using a SS441 hall device I was able to get closed loop spindle control working using an input on my Gecko G540.  The G540 is controlling the spindle speed via PWM.
Is there a way to trigger an emergency stop if the spindle RPM is significantly different than what is being set?
For example, if I set the spindle to 1000 rpm but the closed loop control sees 0 RPM (or anything under 900RPM) is there a way to make MACH3 do an estop or trigger a fault?
Re: can closed loop spindle control be used to trigger estop when rpms wrong?
« Reply #1 on: December 16, 2010, 02:01:33 PM »
Have a look at this thread, this VB in the  macropump should work.
http://www.machsupport.com/forum/index.php/topic,16290.msg110182.html#msg110182
« Reply #2 on: December 17, 2010, 06:48:34 AM »
Thank you, I will give this a shot in the next few days.
