May 27, 2012, 08:25:39 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Using Include Files
Pages: 1   Go Down
Print
Author Topic: Using Include Files  (Read 339 times)
rrc1962
Active Member
Offline Offline
View Profile
« on: December 14, 2010, 08:06:20 PM »
Can you use include files in VB Script?  I have a few functions that need to be attached to more than one button script.  I'm trying to avoid duplicating each function on each button script.  There are parameters that could change in the functions and I'd rather just have to deal with one copy.
BR549
Active Member
Offline Offline
View Profile
« Reply #1 on: December 15, 2010, 10:14:06 AM »
HUM I don't think so, would be nice though update one update all(;-)
DaveCVI
V4 Screen Contributor
Offline Offline
View Profile WWW
« Reply #2 on: December 16, 2010, 01:42:04 AM »
There is an include facility in Mach - if you are running mach 3.43.6 or later.
mach spells it "#Expand"
For more info see the programmer ref manual at http://machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
Expand is one of the later sections in the document.
www.CalypsoVentures.com
Pages: 1   Go Up
Print
Jump to:
