May 27, 2012, 08:25:15 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Need help! Problem with continuing a paused session
Pages: 1   Go Down
Print
Author Topic: Need help! Problem with continuing a paused session  (Read 263 times)
stankovic
Holding
Offline Offline
View Profile
« on: December 14, 2010, 06:45:29 PM »
Helo
I've just recently started using Mach3 software with my cnc machine so this may be a very simple thing  but i am lost at the moment Sad
When i stop the machine during a session i write down the current g-code line so i can start from there tomorrow. After closing the program and turning it on again,i load the g-code and input the line form yesterday. I send the machine to my pre-set zeros, and here's the problem, they do not mach the ones form yesterday! Sometimes they are off by 1cm some times nowhere near it!
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: December 14, 2010, 07:13:02 PM »
Do you have home switches? If not then you really need to have a fixed point that you can reference to.
Pages: 1   Go Up
Print
Jump to:
