May 27, 2012, 08:00:07 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  how can i make 3d parts????
Pages: 1   Go Down
Print
Author Topic: how can i make 3d parts????  (Read 492 times)
cncboricua
Active Member
Offline Offline
View Profile
« on: December 11, 2010, 02:01:19 PM »
Hi i new to this.....
 i could make without any problem the roadrunner sample, but when i import a 3d object from autocad to lazycam,
the generated toolpath is not what i expected.....what i'm doing wrong, mach3 is capable of doing 3d objects with four axis (I ithink so!!!)
there is another software tat i could use to make the 3d objects.....any help?Huh
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #1 on: December 11, 2010, 02:29:21 PM »
LazyCAM is 2D only. You need 3D CAM software to use 3D models.
Tweakie.CNC
Active Member
Online Online
Super Kitty.
View Profile WWW
« Reply #2 on: December 12, 2010, 08:42:17 AM »
cncboricua,
You can pay all sorts of money for different 2.5D software packages but until you decide exactly what you require then perhaps the free version of CamBam is worth looking at http://www.cambam.info/downloads/ . If you like it then perhaps the full version may be worth purchasing of alternatively both Gerry an I have in the past used DeskProto and MeshCam, both of which, I think, still have time limited trial versions to try. There are some more details in this thread http://www.machsupport.com/forum/index.php/topic,13766.0.html.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
cncboricua
Active Member
Offline Offline
View Profile
« Reply #3 on: December 13, 2010, 06:18:00 AM »
how can i get 3d cam?Huh?
Tweakie.CNC
Active Member
Online Online
Super Kitty.
View Profile WWW
« Reply #4 on: December 13, 2010, 06:50:59 AM »
Worth a try.
http://www.bobcad.com/promotions/bobcad_free_demo.php?kid=G1DI16&gclid=CM-or-GU6aUCFUkhfAodhxqutA
Global Moderator
Offline Offline
View Profile
« Reply #5 on: December 13, 2010, 05:07:44 PM »
For free or to purchase?
Pages: 1   Go Up
Print
Jump to:
