May 27, 2012, 07:52:46 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Screen designer tips and tutorials
| | | |-+  Add/Remove Screens in Screen4
Pages: 1   Go Down
Print
Author Topic: Add/Remove Screens in Screen4  (Read 621 times)
rrc1962
Active Member
Offline Offline
View Profile
« on: December 09, 2010, 09:33:32 AM »
I'm probably overlooking something very simple, but I can't seem to figure out how to add and remove screens from a screenset in screen4.  I want to add a couple of custom screens and remove a couple of the standard screens that come in the standard Mill profile.  If I select file>new from the menu, it wants to start a new screenset, not just add another screen to the current screenset.  Does anyone know how to do this?
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: December 09, 2010, 10:42:58 AM »
To add a screen, go to the page# you want and start adding things to it.
To remove a screen, just remove everything from it. And make sure you have no buttons that take you to it.
Basically, I think every sceenset contains the maximum # of pages. The majority of them are just empty. You don't add or remove pages, you just use the ones you want.
rrc1962
Active Member
Offline Offline
View Profile
« Reply #2 on: December 09, 2010, 12:55:18 PM »
Thanks Gerry.  Is there a VB function to bring up a custom screen where you can specify the screen number?  I see OEM functions that open specific panels like, diags, settings, MDI, etc, but nothing to open a custom panel.
Edit:  I may have answered my own question.  I see that OEM codes 1-7 are for Mach screens but I also see that the next code used is 100.  I'm guessing that OEM codes 1 - 99 are reserved for screens so a button using OEM code 50 would open screen #50.  Is this correct?
« Last Edit: December 09, 2010, 12:59:53 PM by rrc1962 » Logged
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #3 on: December 09, 2010, 01:14:06 PM »
50 is a special screen, so it's different. The TAB key toggles #50, and I think OEM 323 toggles screen 50 on and off. But yes, all the rest are OEM 1- whatever.
I believe there are VB functions as well, something like Setpage() and Getpage(). See the manual on the documentation download page.
Pages: 1   Go Up
Print
Jump to:
