Hello Guest it is June 11, 2026, 03:23:07 PM
Author Topic: Driver test question.............  (Read 22903 times)
« on: December 06, 2010, 10:50:21 PM »
I have been having multiple problems with my Blacktoe V4 2X4 setup. I was told to run the "driver test". It is listed in the folder but will not run. Does anyone know where I might find a back up copy that will start & run?
Re: Driver test question.............
« Reply #1 on: December 07, 2010, 12:19:07 AM »
Did you shut down Mach3 before running the driver test?
  •  9,356 9,356
« Reply #2 on: December 07, 2010, 10:16:32 AM »
Generally if the driver test does not run then the drivers are not installed. Try downloading the latest version of Mach and re-installing, this should solve your problem.
« Reply #3 on: December 07, 2010, 10:33:23 AM »
I thought that running the driver test installed the driver, if it wasn't already??
Gene, what kind of problems are you having?
« Reply #4 on: December 07, 2010, 10:39:00 AM »
That is correct.
  •  9,356 9,356
« Reply #5 on: December 07, 2010, 11:18:22 AM »
Do you have any other suggestions for why the driver test doesn't run then ?
« Reply #6 on: December 07, 2010, 01:18:52 PM »
What is meant by it doesnt run, is it opening and not doing anything or is it not opening at all?
How are you trying to run it?
« Reply #7 on: December 07, 2010, 01:38:29 PM »
When I try to run "Driver Test.exe, it will not open or run. The file shows that there is 328KB in the file,but it just will not start. This is while Mach3 is not running.
« Last Edit: December 07, 2010, 01:41:05 PM by gene8522 »
« Reply #8 on: December 07, 2010, 01:52:33 PM »
Disable any antivirus you have and see if that helps.
« Reply #9 on: December 07, 2010, 03:46:46 PM »
The computer that I run Mach3 on is not hooked to the internet, And Mach3 is just about the only thing on the hard drive.
« Last Edit: December 07, 2010, 03:52:00 PM by gene8522 »
