Hello Guest it is June 11, 2026, 10:19:52 AM
Author Topic: New computer MOB needs Parallel port  (Read 10389 times)
« on: December 06, 2010, 06:29:14 PM »
I have an old PC runing my CNC lathe.  I would like to have a new system to replace the the old PC.  The current gen of PC's don't have parallel ports installed on the MOB.  Will a parallel port card added to the PCI slot work as replacement?  What changes do I need to make to the new system?  I am running Win XP operating system.
Offline tivoi
  •  29 29
Re: New computer MOB needs Parallel port
« Reply #1 on: December 06, 2010, 06:34:58 PM »
yes, i think it will work with PCI to LPT card
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: December 06, 2010, 09:30:41 PM »
Some PCI LPT cards will work and some won't. You'll want to make sure you get one with 5V outputs. Also make sure that the card does not take any drivers, it must be a true parallel port not a printer port.
The other option is to use an external motion control board such as a SmoothStepper, KFLop, etc.
Happy machining , Jeff Birt
andrewm
« Reply #3 on: December 07, 2010, 03:06:20 PM »
An external motion controller would cost more but would be a better choice, in my opinion.
« Reply #4 on: December 07, 2010, 05:06:06 PM »
Where can I go to learn about an external motion controller?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: December 08, 2010, 07:04:08 AM »
Well I'm biased towards the SmoothStepper: http://www.soigeneris.com/SmoothStepper-details.aspx, look in the documentation section (link on left of page) for the manuals, etc. (Disclaimer, this is my website.) There is also the KFlop, and DSPMC, Galil, etc...
« Reply #6 on: December 08, 2010, 03:46:27 PM »
Ok thanks
You  have been a big help.
