May 27, 2012, 10:55:13 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  New to mach3. Need help please.
Pages: 1   Go Down
Print
Author Topic: New to mach3. Need help please.  (Read 410 times)
Araknid01
Active Member
Offline Offline
View Profile
« on: December 06, 2010, 01:47:49 PM »
Is anyone here from the northern Virginia area?
I am building a laser cutter/engraver and am looking for someone near me that is experienced in initial setup.
Thanks in advance for a reply.
Eric
ostie01
Active Member
Offline Offline
View Profile
« Reply #1 on: December 06, 2010, 04:02:25 PM »
You could ask some questions to members, I'm sure they can help even if they are on the other side of the world.
Jeff
Tweakie.CNC
Active Member
Online Online
Super Kitty.
View Profile WWW
« Reply #2 on: December 07, 2010, 11:23:54 AM »
Jeff is quite right, we are all over the place but we are all joined up with little wires and communicate with each other just like a breakout board and set of gecko's.  Grin
Seriously though Eric, we are all here to help you, just ask away.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Araknid01
Active Member
Offline Offline
View Profile
« Reply #3 on: December 07, 2010, 11:52:04 AM »
Thanks all for the kind words. I already feel like I'm part of the family here.
What I've built is a laser cutter/engraver based off of the build on www.buildlog.com. Bart Dring's design. He has been more than helpful through the process.
My stepper setup is a three axis xyz configuration. Machine is now built and I'm needing to get the basic motor tuning setup. I'm running nema 17 motors through a geckodrive g540. Where do I start? Setting up home stops etc? Is there a video for this or can someone walk me through please.
Thanks in advance
Eric
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #4 on: December 07, 2010, 02:29:28 PM »
There are videos on the ftp site which explain the basics as well as more complex things, you will find them here ftp://anonymous@machsupport.com/Videos/
Pages: 1   Go Up
Print
Jump to:
