Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 10:54:52 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Hotwire heat control with mach3
Pages:
1
Go Down
« previous
next »
Author
Topic: Hotwire heat control with mach3 (Read 691 times)
mark s
Active Member
Offline
on:
December 05, 2010, 10:51:39 PM »
I have a hobby cnc 4AUPCWHC rev4 driver board with a microchip to control heat on off and heat up down. Will mach work with this?
If not or if someone has a good way to do this with mach please help.
thanks
Mark
Active Member
Offline
Carnoustie, Scotland
Re: Hotwire heat control with mach3
Reply #1 on:
December 06, 2010, 07:11:47 AM »
Shouldnt be a problem but how its done will depend on how the Heat Up/Down is actually accomplished.
Tweakie.CNC
Active Member
Online
Super Kitty.
Reply #2 on:
December 06, 2010, 07:38:49 AM »
Mark,
Not many people seem to be using Mach3 for foam cutting so there is not much of an information database. This thread may be of interest to follow
http://www.machsupport.com/forum/index.php/topic,15968.0.html
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
mark s
Active Member
Offline
Reply #3 on:
December 06, 2010, 01:01:20 PM »
Hood,
Im not to worryed about the heat up and down I use the same 98% of the time.
Tweakie,
I read that post before posting it's all about axis move.
Mark
Active Member
Offline
Reply #4 on:
December 06, 2010, 01:28:15 PM »
Switch on and off could be done many ways but the easiest would likely just be a relay and maybe use the spindle relay output or even the coolant output. Using either of them would just require M3/M5 or M8/M9 in the code for starting/stopping.
How does the heating operate at the moment?
mark s
Active Member
Offline
Reply #5 on:
December 06, 2010, 08:07:37 PM »
Right now a manual switch
Active Member
Offline
Reply #6 on:
December 07, 2010, 02:56:19 AM »
Ok so how would it work normally? Is it just an on/off with some sort of variable thermostat that is manually set?
mark s
Active Member
Offline
Reply #7 on:
December 07, 2010, 04:22:09 PM »
Its a 0 to 35VDC power supply. The power supply has a dial to turn the volts up and down.
Right now I set the volts turn on the power to the hotwire and then run the cut cycle.
I do not change the voltage very offten. On Off would be nice so it will shut off with code.
I got some input on this he told me --Hotwire, use spindle out, on modbus or Pokeys for analog control, use any output pin for just straight on/off.
I do not know about modbus or pokeys?
Would this be the same as the spindle on off wireed with a relay setup?
Mark
Active Member
Offline
Reply #8 on:
December 07, 2010, 04:28:38 PM »
If its just on/off then yes a relay would be the easiest way and just using the spindle commands (M3/M5) to switch on and off would likely be the simplest, especially if using CAM to generate the code as it will likely insert the M3 and M5 for you. Also using the spindle it will allow you to set a delay if needed for the wire heating up.
mark s
Active Member
Offline
Reply #9 on:
December 07, 2010, 05:53:35 PM »
I think I have a relay laying around I will try it in the next day or two.
Mark
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
