Hello Guest it is June 11, 2026, 08:01:30 AM
Author Topic: Disabling I/O during file loading  (Read 7395 times)
« on: December 03, 2010, 11:44:54 AM »
When Mach3 loads a file it runs through a simulation of the g-code. What variable can a plug-in check to determine if Mach3 is in this simulation mode? I'm creating a plug-in for an I/O board, and I/O is being executed during program loading, and that's what I will need to prevent.
Thanks.
Re: Disabling I/O during file loading
« Reply #1 on: December 06, 2010, 07:56:51 AM »
before your code block that you are loading the g code with, put this:
if( !GetLED(67) ) //if OEM led for offline is NOT on
   DoButton(178);//button press for putting mach offline.
//**** Your load g code, code here********
if( !GetLED(172) ) //G-Code is done loading LED.
    return;
else
   if( GetLED(67) ) //if OEM led for offline IS on
      DoButton(178);//button press for putting mach back online again.
      //advance to your next sequence, switch, or statement.
//scott
« Reply #2 on: December 06, 2010, 08:18:16 AM »
Thanks.
I'll monitor 67 and 172, it sounds like that's exactly what I needed.
Frank
« Reply #3 on: December 07, 2010, 11:21:56 AM »
SCott if you go offline with MACH do you loose positional reference??
Just curious, (;-) TP
Offline smurph
  •  1,575 1,575
« Reply #4 on: December 11, 2010, 12:27:09 AM »
Mach is generating the tool path at this point, so it's not a true simulation.  MainPlanner->PathGenerate is set to true when the gcode file is loading.  Stick this in your update loop to keep your plugin quiet while loading a file:
Code: [Select]
if (MainPlanner->PathGenerate) {
return;
