Hello Guest it is June 12, 2026, 11:33:10 AM
Author Topic: Pokeys + LCD + 3MPG + Joysti + botones  (Read 32273 times)
« on: December 02, 2010, 11:11:44 AM »
hello.
I'm new, from Spain,
I have a router running Mach3 and Pokeis55, I have a 4x20 character LCD, but I can not see the values of the DRO, XYZ and A. This solved this?.
Gracias
Offline borisz
  •  220 220
    • www.poscope.com
Re: Pokeys + LCD + 3MPG + Joysti + botones
« Reply #1 on: December 02, 2010, 11:47:49 AM »
Mach plugin for PoKeys  on www.poscope.com
Read manual in plugin.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: December 02, 2010, 03:42:34 PM »
hello.
comfiguracion LCD's work,
ok but how to operate the lever potentiometers. is also the progracion macropump and VB, or directly by the pokesys55,
gracias
someone who has developed this before? There are examples, photographs, etc. .. of work?
Gracias desde Barcelona
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: December 02, 2010, 04:08:21 PM »
Just use PoPendant settings in plugin and all hould be configured
regards
Boris
« Reply #4 on: December 03, 2010, 11:06:17 AM »
hello.
can prevent flickering of the LCD, used by the Pokeys?
 Gracias
« Reply #5 on: January 06, 2011, 06:31:28 PM »
hi from spain
I am waiting my pokeys
Espero lo hayas podido configurar
Saludos
« Reply #6 on: January 07, 2011, 02:58:24 PM »
hello.
 continuous creation of a control panel.
 45 keys.
 3 MPG.
 1 display.
 1 4-axis lever
 1 touch pad.
 4 potentiometers.
I need help.
 the display works.
 the 3 MPG. work.
 but I need to program the keys on the multiplexer.
 and support for the 4 analog inputs
y para el español, donde estas, tienes alguna idea de mi problema?
Gracias
« Reply #7 on: January 07, 2011, 11:28:40 PM »
At the moment I haven´t it.
No me ha llegado todavía, Caripean, cuando lo tenga tengo que configurarlo y ya te contaré como me va.
Regards
« Reply #8 on: January 18, 2011, 11:01:36 AM »
hello.
 I configured the three MPG and works .. 47-key keypad with 10x5 matrix, and it works. LCD works with Macropump system.
 I do not understand the analog inputs.
 My intention is to control 4 functions;
 1 FRO
 2 speed spindle
 3 MPG feed rate
 4 Slow Jog Rate
 someone can show examples of use and control of the analog inputs?
 Gracias
« Reply #9 on: January 19, 2011, 12:05:32 AM »
when you set the 1st four, analogs (starting at lowest pin number), for analog in, then if you will look at the OEM "PoKeys.set" screen set, on the PoKeys page in that screen set, you will see 4 analog input DROS that should change value as you turn yoru pots. NOTE: READ the Flash HELP by pushing the HELP button in the PK config dialog of the plugin!!!
then in Brains, or Macro pump, your choice.  Map the analog UserDROs to the funcs you want.
See "Brains users guide" in the member docs section further down. in this forum......
scott
